Smart Home Android App won't launch Doorbell Answer
Having any issues or recomendations for the Amcrest Smart Home Cloud? Post them here.
rich2dive
Post by rich2dive »
Smart Home Android App won't launch Doorbell Answer. The app was installed on an android device allowing all of the required permissions (audio, video, notifications, etc). However, when the doorbell is pressed (either AD410 or AD110), a “Someone is at Doorbell” notification is sent to the Smart Home App device, tapping the notification does not open the call screen (as defined in Amcrest materials or as in the iOS app). In fact, it takes you to the last event (not even the current event) which could be days old.
Is there a Bug? Is something not setup correct?
RowanR
Re: Smart Home Android App won't launch Doorbell Answer
Post by RowanR »
Bump I am having the exact same problem on an android pixel8. The initial setup the incoming call notification works, then it stops working after than. I get teh notification but no prompt to answer the call.
RowanR
Post by RowanR »
bump has anyone else had this issue?
RowanR
Post by RowanR »
I actually am in contact with Tech support, they requested some video of the issue. They submitted the issue to the development team, hopefully there will be a response soon.
IPCAMDUDE
Post by IPCAMDUDE »
I am not getting any notifications from my AD410 and it's not ringing my phone anymore. The events are registering in the application, but no notifications. This was great before.
