Amcrest Smart Home Android Version: 3.13.1
Phone: Google Pixel 6 Pro - Android 14 (May 5,2024)
When setting up a camera such as the ASH41-B via Amcrest Smart Home, if using static IP settings, you are only able to set the IP address, not the netmask, gateway, DNS, etc. You can only enter an IP address:
Please add the option to select either DHCP or Static IP. If a Static IP is chosen, please allow the option to save IP address, netmask, gateway, and DNS settings.
