Disable camera stream
kurak38
Postby kurak38 » Fri Aug 02, 2019 10:43 pm
Not sure if this is correct board.
I wanted to ask if anyone knows about an option to disable the stream remotely. The idea is that the camera can stay plugged to power and connect to WiFi, but I don't want it to stream video. I use it as baby cam and I don't want it to stream all the time, just when I manually enable it. So far I had to cut the power and plug again to achieve it.
I couldn't find any feature like that in Chrome plugin (Web UI).
Ideas?
jack7
Re: Disable camera stream
Postby jack7 » Sat Aug 03, 2019 11:41 am
In Web UI, go to Setup/Video/Overlay/Privacy. Enable it and select the part of the image you want private. Save. You may also need to disable audio in Camera/Audio. Save.
You should also be able to do it in your router with "Access Control", or some similar name, to specify when the camera is accessible.
Return to “Amcrest Surveillance Pro”
Who is online
Users browsing this forum: No registered users and 1 guest
