Will Doorbell Camera (AD110) work with multiple chimes?
jpage4500
Post by jpage4500 »
I recently bought this doorbell camera because I wanted an RTSP feed as well as no monthly subscription fee. When opening the box I saw the 'chime kit' which needs to go on a doorbell chime.
I've been searching and searching and can't find an answer to the question -- what if you have more than 1 doorbell chime?
Will I need multiple chime kits? If so, where can I get them? I can just try to connect the doorbell camera to see what happens but would like to know before doing the install
thanks,
joe
Re: Will Doorbell Camera (AD110) work with multiple chimes?
Hello Joe and welcome to the Forum
So in short you will only need 1 Chime Kit and will need to be installed in the unit nearest the doorbell camera and transformer...
However my question is how are you installing a dual chime system as I guess it could come down to your system design on where the placement needs to be
