Sensitivity and Threshold? and...BUGS
gammy999
Post by gammy999 »
I am trying to understand the following:
1) What pc app do most use to tweak this>
2) Is a higher Sensitivity number mean it's "less" sensitive?
3) What is threshold?
4) I am having the "bug" storm at night...someone said: "sensitivity=60 and threshold=30"...ideas?
Melvin
Re: Sensitivity and Threshold? and...BUGS
Post by Melvin »
Hi gammy999,
gammy999
Post by gammy999 »
Thanks Melvin..nice...so, the lower the SENSITIVITY the more sensitive it is? i.e. 1=1percent change...and the lower the threshold the bucket feels up quicker so it makes it more sensitive...correct?
longedge
Post by longedge »
"the lower the SENSITIVITY the more sensitive it is?"
Exactly the opposite as I understand it - 100 = most sensitive and 1 = least sensitive. If that is not the case then it's no wonder that I have never been able to find a setting that works reliably. I've given up on it now and as far as I'm concerned the camera is just a toy and most certainly not a reliable security device.
My AMCREST Cameras:-
Melvin
Post by Melvin »
Hi gammy999,
Its higher the sensitivity its more sensitive.
gammy999
Post by gammy999 »
I'll give it a shot...looks like you have to do this through Amcrest Web View...another good post on this:
https://amcrest.com/forum/technical-dis ... t8954.html
doel13
Post by doel13 »
I have been playing with this. Each camera location has to be setup differently. I use the Web View's Detection Area Setup for this where the graph displays in real time all the triggers. I selected the area. Started with Sensitivity 75 and Threshold 5, and watch the smaller graph (on the lower right of the screen) for a while. Sometimes I see the triggers goes beyond the threshold (shown in red) even thought there is nothing. I assume it was trigger "noise" so I upped the threshold and watch again. Kept doing that until I find the proper setting.
IP2M-851E with remote FTP for snapshots.
