QUESTION: Using the Amcrest View Pro app on Android
kpindc
Post by kpindc »
Hi all. I have a question. Is there a way to go directly to the camera presets when using the Android app? If so, how? I haven't managed to find it. I am always swiping back and forth to move the camera position/view, but I'd prefer to be able to tell it to go to preset 1, preset 2, etc.....like I can do when using the computer. Please let me know. Thanks...
Melvin
Re: QUESTION: Using the Amcrest View Pro app on Android
Post by Melvin »
Hello kpindc,
You can go to the camera presets using Amcrest view Lite/pro applications on your android device. For this, when you are on the live view page, click on the circle to enable PTZ and you will see an icon that looks like a "Flag'. Tap on this and it gives you access to the presets, select the preset number on the right most box and click the tick mark and it goes to that preset.
