PTZ moved on its own
tjsand2002
Post by tjsand2002 »
I went on vacation and was out of cellular service so I could not monitor my PTZ camera. When I returned I saw it was turned completely to the side. When I reviewed my NVR I find the last spot where it is in position and recording fine and then there is approx a 1 min lapse in recording and when it resumes it is turned completely to the side. Is there an explanation as to how this could occur?
Re: PTZ moved on its own
Hello, I am not sure of your PTZ model and I am going to toss out a Guess here...
Seeing you PTZ didn't return home I am going to assume that you don't have any PRESETS setup... Most PTZ are setup to have what is called a Guard Position and it can return there after a Set time with no action/input from user. So it could be that your PTZ reset on a Normal day you have it setup to reset and it didn't go back to your normal location. This might be where the North is set if so set...
I know with my PTZ after no action for 1 min it returns to Guard aka Preset 1
James
JVRx77
Post by JVRx77 »
Another option is to check the cam's log file for login's... if there's one that's unaccounted for, perhaps a more secure password is needed...
John
