I've just set up my second camera and in the process of testing it. Since my first camera points outside and has the IR lights off for recording through a window, I'm not familiar with using a camera with the IR lights on.
So, the second camera is in a darkened room with some light entering through the hallway. When I view with Live View, the scene is fairly well lit and in color. But there are intermittent bright flashes, at which time the room is brightly lit, and after a short time returns to the normal state and then starts the whole process all over again. There's no movement that's triggering anything and I can't find anything in the settings to change. Any suggestions as to what might be causing the constant flashes and what to do about it?
Thanks.
Night Vision and Bright Flashes
Amcrest IP2M-841 ProHD 1080P
Re: Night Vision and Bright Flashes
Okay, it looks like I figured it out. The camera is on a shelf between a box and a plastic storage container. I think the lights might have been reflecting against the plastic next to the camera. I moved the plastic container back so it wasn't in the field of view and when I just looked at Live View, there were no flashes. The video's also streaming in black and white, not color like before. So it's working like I would have expected it to.
