Netvue cameras
jakthree
Netvue cameras
Post by jakthree »
Hi,
Amcrest NVR: NV2104, NV4108E-HS
I was given two Netvue NI-1901 outdoor bullet cameras. I factory reset the cameras and they grabbed an IP address from my router. On the NVR(s) GUI, I tried to search for the cameras but they didn't show up. The camera's documentation doesn't say anything about being ONVIF compatible.
Does anyone if the NVR(s) can be made to work with the Netvue cameras?
Thank you,
Re: Netvue cameras
I am going to guess you might be better off finding someone at Netvue that can answer that one. I have a few different IP cameras that are not able to connect to my Amcrest NVR's or DVR's without running RTSP that don't work well yet they work within the same format as their own brand with out a Hitch. What I know about Amcrest NVR's that I own anyway I don't own all of them. Ones I do will work with Onvif cameras outside of the Amcrest family however not all of them.. Also as I said above some will only work on their own Recorders and some only on one type of their own brand at that..
