Motion is detected but not recorded
danik56
Post by danik56 »
I have setup motion detection to record and take a snapshot.
I get the email with the snapshot when the motion is detected but nothing gets recorded or at least nothing shows
up under the playback tab.
Can someone advise how to fix this ?
Camera is IP3M-943W.
Melvin
Re: Motion is detected but not recorded
Post by Melvin »
Hello danik56,
For the play back to show recordings, you need to set up recording to an SD card. Schedule must be set up for motion detection recording and destination should be selected as SD card.
relentless214
Post by relentless214 »
Same issue. I can not get the playback for video. I can for snapshots. Motion detection is set up to record. Manual record is not working. If I set to general record it will record and use up sd disk space but I can't see any files in the playback. Note: I have 8 IP3M cameras, 1 camera was working fine, when I restarted the camera it will not record properly now as well. I have factory reset the cameras and still no avail. Also tried re-inserting cards with no joy... Is this just a firmware bug?
Melvin
Post by Melvin »
Hello relentless214,
If its recording but not showing up in playback, can you please try using Amcrest Surveillance Pro software?
https://support.amcrest.com/hc/en-us/ar ... llance-Pro
