IP2M-841B with backdoor?
Tungsten E2
Post by Tungsten E2 »
How to find out if IP2M-841B is affected by Dahua backdoor?
http://blog.nsfocusglobal.com/categorie ... -solution/
jantman
Re: IP2M-841B with backdoor?
Post by jantman »
It seems like a lot of the original information about this vulnerability has been taken down (note it's now quite old - it was announced over a year ago) but it was quite well-publicized, including viaKrebs on Security and ThreatPost. There's a free online checker for cameras with public IPs (eek! scary!) here and the proof-of-concept code can be found on Exploit DB. There's also a post on IoTsploit's blog about it.
I checked two cameras that I just bought last week - IP2M-841B (2.520.AC00.18.R, Build Date: 2017-06-29) and IPM-723W (2.400.AC02.15.R, Build Date: 2017-07-31) - and they're both reporting as being patched.
Tungsten E2
Where did you get your fw? My version is IP2M-841B-EGD-DE 2.420.AC00.16.R, build : 2016-09-09
And I still have the smtp time bug.
jantman
Post by jantman »
Tungsten E2 wrote:Where did you get your fw? My version is IP2M-841B-EGD-DE 2.420.AC00.16.R, build : 2016-09-09
I just bought my 841B via Amazon last week; this is the firmware that shipped on it. However, my version is available for download from https://amcrest.com/firmwaredownloads
Tungsten E2
thx, updated IP2M-841B with fw for IP2M-841 to fw version 2.520.AC00.18.R, Build Date: 2017-06-29
fixed the wrong time in smtp as well. but the cam web server seems to hang frequently.
within the past 48hrs I had to reboot the cam twice. IP got timeout, while ping was successful and LED was green. connected via LAN.
do you have the same problem?
