Internal ip addresses
SteveB
Post by SteveB »
Both my IPM2 841 PRO cameras have both their IP's listed as wired in my router. I can't delete one of the addresses on either camera, without deleting the other IP address. One of the IP addresses on both cameras (I'm guessing the wireless IP address) is constantly disconnecting and reloading. How can I get only 1 IP address (wired) from each camera to show up in my network?
t84a
Re: Internal ip addresses
Post by t84a »
If you are using hardwired and use static address, just ignore the wireless IP. As far as I know, you can't disable wifi. Make sure you set wired to default.
SteveB
Post by SteveB »
Thanks for the response. I just don't like that the other IP addresses are constantly reconnecting.
t84a
Post by t84a »
I hear you but these are cheap cameras relatively speaking.
longedge
Post by longedge »
It would be good to be able to disable WiFi. In my experience it just doesn't work reliably. My camera is fine on ethernet and just now and again it also grabs an IP as a wireless device. Like most p.i.t.a's best just ignored I suppose.
My AMCREST Cameras:-
t84a
Post by t84a »
Something hit me, did you clear out the SSID and passkey? It shouldn't be able to connect to a wifi network without that.
longedge
Post by longedge »
Ha!!! Went to look at settings for WiFi with the intention of trying that suggestions and there staring me in the face is a check box "Enable Wi-Fi". Unticked it - gone.
