I am interested in using the sub stream on my amcrest with tinycam... I notice when I load the main stream in tinycam there is a lag of 2-4 seconds before it loads. I'm hoping that using the sub stream that it might load faster in tinycam since the sub stream is set to a lower resolution.
I saw a post about using ONVIF profile and channel 2? But I tried many variations of settings and can't seem to get it to work?
I have amcrest 841.
Inputs TinyCam needs:
Vendor: (tried ONVIF)
Model: Profile S
IP: 192.168.29. X (setup a static ip, i've also have a no-ip domain setup)
PORT: X (I think this is the http port?, which i customized but in amcrest there is tcp:37777 udp:37778, http, rstp ports)
Protocol: snapshot, http, RTSP over tcp, RTSP over UDP
RTSP Port: (i customized this but i think default is
HTTPS encryption: Y/N
Channel:
amcrest setup:
static ip
no-ip domain
modified http port
modified rtsp port
modified admin password
setup port forward for the modified ports
enabled onvif
enabled sub stream
Any suggestions?
Thanks!
How do you setup Amcrest Sub Stream with TinyCam?
Re: How do you setup Amcrest Sub Stream with TinyCam?
try asking your question on the Google+ group for Tinycam
