How do you initiate a manual recording to the SD card?
nboemio
Post by nboemio »
Hello,
Probably a stupid question, but I can't figure out how to initiate a manual recording to the SD card that I have plugged into the camera. Is this possible? Or are only events recorded to the SD card?
Also, how would I manually record to the cloud storage as well.
Thanks.
nboemio
Re: How do you initiate a manual recording to the SD card?
Post by nboemio »
My camera is IP3M-941.
jack7
Post by jack7 »
To manually record to SD card, go to settings/storage/record control.
Record mode is normally set to Auto. Change it to Manual, and then Save to start recording. To stop recording, change it back to Auto, and then Save. When searching for the recording, specify "All" records or "Manual" records.
