I bought this on Amazon - I believe from Amcrest Direct, several years ago.
Can someone suggest which firmware I should download? There is listing for that specific model.
Much appreciate any insight here. Thanks!
Firmware for IP2M-841B-UK
Re: Firmware for IP2M-841B-UK
Hello and welcome to the forum.
Do you have a problem that you need to resolve? What version do you currently have installed?
My AMCREST Cameras:-
Thank you
I don't have a specific problem, just the camera has not been used in some time and I am putting it back in service. I figured it makes sense to update the firmware for security purposes.
Software Version V2.420.AC00.18.R, Build Date: 2019-08-03
WEB Version 3.2.1.619604
ONVIF Version 16.12(V2.4.1.513183)
You can search for the latest firmware here - https://amcrest.com/firmware#searchbox
The camera is I believe obsolete now. I think there is a more recent firmware version available than yours and mine but for my own purposes it's a case of if it aint broke.....
I don't require remote access so for security, I deny access to the WAN for all my cameras in the camera network settings and also in my router settings.
