I'm using Chrome and IE, and get an error/popup every time I start the DVR Web Access Application that goes with my Amcrest cameras and DVR.
The exact error is "Please install the plugins first! comstring_npapitps", when I attempt to login to my cameras... in my case https://192.168.1.99.
I've downloaded the application it wants me to install... webplugin.exe, but once installed, it never helps. I've restarted the browsers, restarted the computer, to no avail. I can't even find anything in the Amcrest forums nor Google when searching for "comstring_npapitps"... wtf? Nobody has run into this before? I find that hard to believe.
Please help.
Thanks,
Dave
comstring_npapitps error when starting DVR Web Access
Re: comstring_npapitps error when starting DVR Web Access
Hello superdave67,
Please try uninstalling and reinstalling the plugins. Also try using Firefox and see if it works.
https://support.amcrest.com/hc/en-us/ar ... 0P-HD-CVI-
You can also get live preview and recordings through the Amcrest Surveillance Pro software.
https://support.amcrest.com/hc/en-us/ar ... llance-Pro
