Can't Connect my IP2M-841B to Synology Surveillance Station
dljone1
Post by dljone1 »
I have just purchased a Synology DS220j NAS and I am trying to add my 2 IP2M-841B cams to Synology's Surveillance Station. I can access my cam's feed through Surveillance Pro on my WIN10 laptops and through the Amcrest View Pro app on my Android phone.
When I try to add my camera through the Synology wizard, however, I can't get it to connect. Any suggestions?
Re: Can't Connect my IP2M-841B to Synology Surveillance Station
If I had to guess I am going to guess that you have changed your Port # and your NAS don't know what port to use.. If you changed your normal port ID then you will need to update that info in your NAS, or any other items that you use with your IP address...
jack7
Post by jack7 »
I don't have a Synology, but you might try 37777 in the port field.
dljone1
Post by dljone1 »
I did try port 37777. It doesn't work either.
