ASH21 - Unable Login with Default 'admin'
JerseySteve
Post by JerseySteve »
Just received the ASH21-W-V2 camera. SmartHome APP (Android) is currently NOT available for download, so I'm trying to set it up using Windows Surveillance Pro or Android View Pro.... In all cases it gives an Error msg "Invalid Login"
I've reset the camera and still no luck.
Any suggestions?
Re: ASH21 - Unable Login with Default 'admin'
That is a Smart home product and Normally smart home products can't be setup to any other device until it is first setup using the Smart Home app. Once it is setup on a Smart Home app then it can work on other platforms like Amcrest View Pro, ASP and or DVR/NVR..
My guess is that it's locked until setup like normal SH devices. I don't have a V2 mine is first run device. Also if the V2 is like the first run then you want to setup Wifi if you intend to use wifi outside the normal app.
