Hi all..
I'm new to Raspberry Pi but have managed to set up a a 4TB external hard disk accessible on RPi v3 accessible via FTP. I have everything working 100% from a Win10 PC running Filezilla to log in to the RPi, upload and download to the desired drive/directory on the 4TB disk. So, it appears permissions, etc. are OK.
However, when testing the connection within the Amcrest Set Up page to the FTP server - it fails (so far, I'm just attempting to get this to work on LAN - Camera: 192.168.1.22 & RPi: 192.168.1.25). I have copied and pasted the destination folder from Filezilla into the Amcrest the destination folder input box. I have tried repeatedly in many different variations of other variables - but all fail. I get an authentication error when I supply a bad username / password; so I have to believe that I'm supplying the correct username / password and am at least getting to the RPi. I can't recall the other errors I was getting as this was while I was setting it up offsite yesterday. I wonder - Has anyone managed to get a Raspberry Pi v3, FTP, external HD and Amcrest cameras to connect and work? And, how did you do it??
Thanks in advance!
Amcrest to Raspberry Pi via FTP?
Re: Amcrest to Raspberry Pi via FTP?
If you can support RSTP streaming onto the Pi, then try the following?
RSTP URL will be rstp://xxx.xxx.xxx.xxx:554/cam/realmonitor?channel=1&subtype=0
User ID will be admin, and password will be whatever you set when you set up the camera (this is me talking from point of view of what I did setting up the AD110 doorbell)
I think the other Amcrest IP cameras should allow this via their web interface?
I have the Onvifer app on android that works perfectly this way, and also QNAP Surveillance Station on my NAS that also works well.
Hope that helps
Hope that helps
Are you trying this via the "test" button? That, at least for a long time, always failed.
Try forcing some event to cause it to do the FTP, see if that works.
What files are you trying to move onto the raspberry pi?
I've written a python3 script that utilizes the Amcrest api to download the files from the previous hour. Crontab it and done... PM me if you are interested in setting it up.
I'm also interested in this so replying to keep track.
I've not been successful in my attempts so far (because I only have a gen1 pi which isn't powerful enough to run its own browser let alone handle video files), but I was looking at using Rclone or something of the sort to host an FTP server and then relay the incoming footage to Backblaze B2.
I have the pi download the files off the camera once per hour. Then it rclones them using WebDAV to a different pi that is running NextCloud, but B2 would work also.
