Amcrest IP4M-1051B Micro SD Card
zplugger
Post by zplugger »
Is this the right card for this camera? Will recording to sd take away the lagging of live view? Live view has a lot of network lagging, need something more real time.
Re: Amcrest IP4M-1051B Micro SD Card
Only thing MSD is going to clear up is Playback of recorded footage to the MSD.. This isn't even 100% because if your wifi is not good enough or there is to many things competing for service it can drop...
Some times Router need to be restarted... Also Routers Ch have a lot to do with how well it can work. Sadly if you look at your wifi area and see there are a lot of people on your wifi ch you might want to change that ch to one that don't have others trying to compete for.... Sadly there are so many people around some are like me have high power routers for long range even and compete for channels. Plus other things in your home and others around your home might be competing for wifi and can cause bad results because of it... At my cabin I have only 1 person out there that I can see from my Long Range Router over a 6 mile range. Where here at the house when I had it setup to see 6 miles I could see over 50 wifi routers now have it lowered to 2.5 miles and still can see 20 or more depending on the hour..
zplugger
Post by zplugger »
Would the camera record to real time when on sd? Must be able to playback sd card on the computer without wifi? Guess what I'm saying is the the camera going to record a event to sd without lagging, so the camera does not need wifi to record a motion to the sd?
Yes that Camera could record to its self without the need of Wifi... The problem is unless you take it out of camera or DL the feed before watching Playback over Wifi could be an issue... Don't get me wrong I do Watch from my MSD on my 751 over wifi late at night I get need to DL I am guessing where there is other traffic more then normal day time when less traffic on wifi grid not meaning my Router but as a whole
It will record as it happens... I have had no issues with any of my PTZ cameras recording on MSD only a no longer supported 751 seems to be starting to die because there are not only loss in Wifi but now loss in MSD recording as well. So it is either a PSU issue or camera going bad.. Same results from all different MSD cards installed and none of them are cheap MSD cards that are fakes only do that once before you learn lol...
