What about us chromebook users?
mrgumhead
Post by mrgumhead »
No view pro app for my chromebook. Is there anyway to access my cams on my chromebook?
I,m running a Amcrest NV4116E PoE NVR
Lenovo Chromebook C330
Re: What about us chromebook users?
Sadly I am going to guess that is Google has made it so you can't access IE then you will need to log into the Firmware page and download the JS FW off the page.. However if your working with 4116E non HS Recorder as it might be from what your Post states then sadly there is no FW update at this time to make your Discontinued NVR work with Chrome... I also have a Couple of Amcrest machines that are no longer getting FW updates and the one my 2116-HS that does have one I will not update for now
However if you have the NV4116E-HS there is a 2020 FW update for it and you can get to the page by clicking on the Support tab under the Phone Number and Clicking on Firmware
jack7
Post by jack7 »
Install android Amcrest View Pro app on your chromebook.
https://support.google.com/chromebook/a ... 1273?hl=en
