Motion detection
Edmiller67
Motion detection
Post by Edmiller67 »
How can get my motion detection to record longer when triggered with the Amcrest View Pro app?
Re: Motion detection
Hello and welcome to the forum
Sadly i personally don't know of a way from the App.. So this only leaves the WebUI and in there you can set how long a Recording Records however I am not sure that is the case for Motion or just full time Recordings... In the App you can only change things like Enable and disable Then in Advanced Config there is Anti Dither, Schedule, Sensitivity, and Region Settings then Able to turn on or off Push Notices. Turn on or off record delay and snapshots... Add Email but no way that I know of for setting Record time on events...
jack7
Post by jack7 »
In View Pro, go to Configuation Center/Motion Detect/camera/Delay. Set Delay from 10s to 300s. Recording will continue after event alarm ends for the specified Delay.
