So had someone ask about how to setup a Schedule for AVP2 so they were not getting push notices at night while trying to sleep. So I thought I would post the answer here as well so others that might be interested in doing the same thing, seeing it is easily overlooked.
When you setup your event be it Motion or IVS, SMD and the like. When you click on your devices push notifications right at the top of the list is the schedule. Just set that time, then you can setup the event you are looking to use. Once you save it will only push to your phone at the times you have setup.
Amcrest View Pro 2 push schedule
