ASP what version do I have installed
jakthree
Post by jakthree »
Hi,
I am running Amcrest Surveillance Pro on Windows 10. I can't find 'About'.
How can I tell what version of ASP I have installed?
Thank you,
Re: ASP what version do I have installed
So in the newer one you click on the man in the top right it will have a drop down click on about
older on on bottom menu click on the right arrow then click on Config gear think it was called General then click on Version it will say 1.41 the new one will be 2.xxxx something
jakthree
Post by jakthree »
I have v1.41. I noticed that I still had the installation file in my Download folder.
Thank you,
You can mark this as solved.
