Amcrest Smart Home - "Network Error" cannot login
Jake20
Re: Amcrest Smart Home - "Network Error" cannot login
Post by Jake20 »
aldouswu wrote: Sun Dec 22, 2024 9:51 am
Birdwatcherr wrote: Sun Dec 22, 2024 9:42 am I can access the app no problem on my iPhone. I can't on my Samsung. Did anyone else update their Samsung with the latest security level patch recently?
This issue started yesterday but the last update on my Samsung phone was on 11/29.
Ok the issue may not be related to the last update then. Not sure if it's a generic Android issue or something specific to Samsung.
Maybe Amcrest has different servers for Apple than Android.
Birdwatcherr
Post by Birdwatcherr »
Jake20 wrote: Sun Dec 22, 2024 9:49 am
I updated earlier this week, but I am pretty sure that the app still worked after that, but not 100% sure.
Anyone try reinstalling the app maybe? May try that.
I reinstalled the app on my Samsung. Checked all my security permissions. Still getting the Network Error.
Birdwatcherr
https://amcrest.com/smarthomesupport
Link to put in a support request
Jake20
Post by Jake20 »
I Also sent them a Facebook message
eclipse
Post by eclipse »
Same problem here in Cleveland starting yesterday, although this is the first time I recall this occurring. So annoying.
mannypalh
Post by mannypalh »
Called amcrest it's android base due to update this week
mannypalh
Post by mannypalh »
Called amcrest it's android base network error due to update this week. They are aware and working on a fix.
honeyhoney1979
Post by honeyhoney1979 »
mannypalh wrote: Sun Dec 22, 2024 11:09 am Called amcrest it's android base network error due to update this week. They are aware and working on a fix.
An update to what this week?
Nicabus
Post by Nicabus »
I don't think it's an android only issue, as I have the app running on Pixel, Galaxy Tab, and iPhone. All devices started getting the config error and when I uninstalled/reinstalled on the Pixel I can't even login now, getting the "Network Error" message. The Tab was a fresh install on a brand new device and getting the "Network Error" message. I think the IPhone only works because the app was already connected when servers had issue. I am still getting the config error on the iphone if I try and update motion detection or any other config.
greeman
Post by greeman »
Same here "Network Error" since yesterday on Amcrest Smart Home. My router shows strong connection on each camera, ip addresses are perfect, etc. Can still connect through Amcrest Survellence Pro, so looks like it is on Amcrest's end. Bummer!
