IP login
elsablack005
IP login
Postby elsablack005 » Tue Jan 08, 2019 9:14 am
hey guys,
I am facing problems to login into IP address 132.168.1.108, i was wondering if anyone of you could help me with detailed steps to login into the IP.
Thankyou.
longedge
Re: IP login
Postby longedge » Tue Jan 08, 2019 1:54 pm
Is that a typo? Do you mean 192.168.1.108
Using IP2M-841B (firmware 2.520.AC00.18.R).
Mystick
Re: IP login
Postby Mystick » Wed Jan 09, 2019 10:29 pm
Not enough info, but you won't be able to login unless you are on the local network.. if you're on the outside you have to set up NAT on your router. If you are on the local network, make sure you're specifying the same port the camera is on.
rafaelsolano
Re: IP login
Postby rafaelsolano » Tue Jan 15, 2019 1:28 am
Like Mystick said, you haven't provided enough information. Also, this seems like a local network IP address. You need to mention the proper configuration.
Anyway, if you're talking about router login, then check out this guide for more details.
mehrdad22
Re: IP login
Postby mehrdad22 » Fri Jan 18, 2019 2:58 pm
whta is subnet mask in ip camera?
http://nadin-co.ir/camera-4
timpaines
Re: IP login
Postby timpaines » Fri Jan 25, 2019 6:05 am
Logging through ip does not create the problem but which device you are using and what kind of ip you are trying to access its matters, https://epsonsupports.net/blog/how-to-f ... ine/helped me to get the login page for the ip address.
Return to “General Security Chat”
Who is online
Users browsing this forum: No registered users and 1 guest
