Surveillance Pro: Black screen during playback but still kbps reading...
swbrains
Re: Surveillance Pro: Black screen during playback but still kbps reading...
Post by swbrains »
Well, I spoke too soon, even with the compatibility settings set as I mentioned them in my previous post, it's back to opening and displaying "Searching video..." for all cameras. :(
swbrains
Post by swbrains »
Update: Those compatibility settings no longer consistently work. However, if I uninstall the Intel UHD video driver and let Windows use it's own basic display driver, it seems to work consistently. Unfortunately that video driver is not acceptable for daily use in Windows. I think this is an issue between ASP and the current Intel UHD video driver.
Thank you for the update info. Be good for others that might be having the same issue..
swbrains
Post by swbrains »
Not really. Like me, I doubt a lot of people will want to remove their GPU's native drivers in favor of a lower-performing "Microsoft Basic Display Driver" to make one app happy. Any app that's video-intensive like gaming will likely be unusable under the generic Microsoft display driver.
I am not sure, I have tested this on all my systems with 1 dual AMD GPU setup, 2 PCs with 1050Ti, GTX1650 and a Super 2070. Each of them are still working without an issue. However my thing is if there was another with an issue they might be able to do what you did to see if it was same type issue. My guess is that it might be MB related. I have even tested some older no GPU systems that are still able to work with ASP and they are still working. Not as smooth as it was once before changing from 1.4ASP.. But still works enough to do what I would want with them.
My reply wasn't meant to be a working solution. Just a way for others that can test to see if it has the same cause..
outflyin
Post by outflyin »
I am having this black screen problem on Windows10 using the old version of ASP. This just started happening recently. It is happening with all of my cameras except one, an IP3M-943W. My cameras are all hard-wired ethernet connected. The video has audio playback, but black screen.
outflyin
Post by outflyin »
Update. I just checked the encoding mode on the affected camera and it was set to H.265. I changed it to H.264H and now it works fine. No idea how it got set to H.265 since I have never changed that setting on any of my cameras.
outflyin
Post by outflyin »
The cameras mentioned in my previous posts are AMC cameras. I am also having this problem with most of my ASH cameras, except one which is an ASH21-W-V3. I don't see any way to change the encode mode setting on these in the ASH app and they are not accessible in the web browser.
