This is what worked for me to disable mechanical chime. Again, a word caution about chaging values via the web-api but I've done this on my own AD110 without issues. You have to set ExternalDoorBell.Enable=false AND set ExternalDoorBell.Type=0. So:
http://<ip address of ad110>/cgi-bin/configManager.cgi?action=setConfig&ExternalDoorBell.Enable=false
http://<ip address of ad110>/cgi-bin/configManager.cgi?action=setConfig&ExternalDoorBell.Type=0
AD110- Can you disable the mechanical chime?
Re: AD110- Can you disable the mechanical chime?
Unfortunately this doesn't work for the AD410. It seems to register with the API but doesn't actually disable the mechanical chime.diyorbust wrote: ↑Fri Apr 08, 2022 1:54 am This is what worked for me to disable mechanical chime. Again, a word caution about chaging values via the web-api but I've done this on my own AD110 without issues. You have to set ExternalDoorBell.Enable=false AND set ExternalDoorBell.Type=0. So:
Is it possible with the AD410?
