Geez Thanks for pointing this out.. I don't look I just copy and paste links. I guess when I did the one for this I didn't get the link and posted another video that I had made for someone that said 50watts though a 5v DC supply was same 50watts he gets when using his Kill A Watt meter and it clearly isn't seeing the Kill A Watt meter is only doing the info from the power supply power.. Again Thank you
Sorry for the wrong LInk to any that watched..
https://youtu.be/EChtdg-c5yM is the right one..
4216E-AI and other 4.0FW Recorders
Re: 4216E-AI and other 4.0FW Recorders
@Revo2Maxx
I sent you a PM about three hours ago. It will not leave my PM Outbox. Please check and see if you can find it and let me know. If not, I could just post it here. It's about the secure P2P part of your post a few posts back.
It is ok. When you post a Message to someone the Message stays in your Out box until the user reads the message then the message is moved to your sent box.. That is the way this Forum type works..
Yeah so I posted something that I thought was cured in the App however after testing again an hour later it wasn't after all so I removed my posts that I had made seeing it wasn't correct after all.
Opps..
Opps..
