IP4M-1028W (DO I NEED A WATER PROOF JUNCTION BOX)
DYNO1
Post by DYNO1 »
I am looking at purchasing the IP4M-1028W camera and I cannot find any Water-Proof Junction Box for this specific camera? Any ideas?
Also would love to know if you can upgrade to a 3.6mm lens versus the 2.8mm? I know it is not much of a difference but for what I need it for it would be that much better
thank-you for your help
jack7
Re: IP4M-1028W (DO I NEED A WATER PROOF JUNCTION BOX)
Post by jack7 »
Get a plastic project box available at Amazon, drill holes in it for cable entry, and seal all the holes, etc.
Update: Sorry, I didn't realize you wanted a box under the camera base instead of one elsewhere.
