Hello there,
I have the following equipment.
4 x ip3m-hx2
1 x NV2108 NVR
1 x Ubiquiti Nano HD Accesspoint 4x4 5ghz band
the system works good for most of the time until randomly one of the cameras looses connection , and it displays both leds in red. I can reboot the ap and it never connects back until I manually reboot the camera unplugging the ac cable. The cameras aren't too far away from the AP , and theres no signal problem.
its a bit uncomfortable to check my security system and one of the cameras is out.
Any help with this issue would be appreciated.
ip3m-hx2 cameras stop responding.
Re: ip3m-hx2 cameras stop responding.
Sound like one of the cameras has problems. Could be a surge. I had one that needed to be unplugged and putting it on battery backup worked for me. It was a PITA to get in the attic and router all the power to an APS but I am glad I did. Surge protector might help avoid the rewiring.
that's the only reply I have received, Ill see If I can get a surge protector to see if there's any difference.
