Wireless internet connection
gps98155
Postby gps98155 » Sat Mar 14, 2015 9:37 am
Can the 960H (4) internet connection be hooked up with usb wireless adapter rather than the either net (10/100 adaptive network interface) connection?
johnnyv
Re: Wireless internet connection
Postby johnnyv » Sat Mar 14, 2015 11:36 am
You should call or email Amcrest to ask that. If you can't, you might consider using a powerline ethernet adapter like this http://www.amazon.com/TP-LINK-TL-PA4010KIT-Powerline-Adapter-Starter/dp/B00AWRUICG/ref=sr_1_1?ie=UTF8&qid=1426353844&sr=8-1&keywords=power+ethernet.
You could plug it into a power socket near the DVR and then plug the other end in near your router. I think you would be happier with that connectivity than with wireless. You want all the bandwidth possible going from your DVR to your router so that you can get a good remote picture. Just a thought.
Another option if you need wireless, would be to use a wifi to Ethernet adapter like this http://www.amazon.com/NETGEAR-Universal-Ethernet-Adapter-WNCE2001/dp/B003KPBRRW/ref=sr_1_1?ie=UTF8&qid=1426354482&sr=8-1&keywords=ethernet+bridge+wireless.
If the DVR can't support a USB wireless adapter, either of those options might work for you.
ethan6757
Postby ethan6757 » Sat Apr 13, 2019 7:05 am
yes you could hookup 960H wireless internet connection with usb adapter, you have to plug it into power socket near the dvr and then plug it into your router.
Return to “NVRs / DVRs”
Who is online
Users browsing this forum: No registered users and 1 guest
