Problem in iPhone 16 PRO Max
Ankan
Post by Ankan »
I have Amcrest View PRO. in my iPhone 11 PRO Max I have seen the whole picture in the surveillance. now I have the iPhone 16 PRO Max, then I see less than half. If I click on the image, I can adjust it so that I see the whole image. What should I do to see the whole picture at once?
DarnIt10
Re: Problem in iPhone 16 PRO Max
Post by DarnIt10 »
I figured out the following compromised work around this morning!!
Set your iPhone 16’s “Display Zoom” to “Default” (standard) in the settings, not “Larger Text”. This is the workaround I just added to my AMCREST issue 568073, which has been with the developers since January.
AMCREST- With this information, please fix ASAP. We want the “Larger Text” option working with your apps. On my old iPhone 12 and iPhone 14, this was not a problem to have “Larger Text” enabled. Both View-Pro apps need fixing as other iPhone 16 video apps don’t have this problem. With “Larger Text” enabled, note that thumbnails display correctly, but Live Viewing and recorded video playback inaccurately crop to the lower right. I have added this info to my issue ticket.
