delete device issue
Fiberfrk
delete device issue
Postby Fiberfrk » Wed Jan 06, 2016 10:29 am
I have a device that I cannot connect to and am unable to delete because when I originally had it set up it had push notifications. The delete option tells me that I need to turn off notifications on that device first before I can delete. I can't get the device to connect to my new wifi - so how do I delete it if I cannot turn off notifications?
Thanks!
burtedwag
Re: delete device issue
Postby burtedwag » Tue Apr 05, 2016 6:14 am
Delete the app. Reinstall. Pray you don't have more than 2 devices.
5states
Postby 5states » Mon Sep 19, 2016 1:02 pm
One option is to hard wire (ethernet) the camera to your router and it should default to the WIRED connection. Then, connect via the online IP of the camera to reset the wifi connection.
salcaide
Postby salcaide » Mon Dec 17, 2018 1:03 am
I cannot believe this is still an issue after 3 years. How do I delete a device that is no longer physically available. It has push notifications turned on, and the App will not let me delete it without connecting to the camera. The camera is gone, as in broken and thrown away.
seraniz
Postby seraniz » Fri Feb 15, 2019 1:18 pm
Fiberfrk wrote:I have a device that I cannot connect to and am unable to delete because when I originally had it set up it had push notifications. The delete option tells me that I need to turn off notifications on that device first before I can delete. I can't get the device to connect to my new wifi - so how do I delete it if I cannot turn off notifications? Redtube Beeg Spankbang
Thanks!
Return to “NVRs / DVRs”
Who is online
Users browsing this forum: No registered users and 1 guest
