I have my 3mp Amcrest camera set at the following settings.. Is there anything I should change to ensure the smoothest recording with the least errors or are these good to go?
Code-Stream Type -- General
Encode Mode -- H.264
Resolution -- 2304x1296
Frame Rate (FPS) -- 20
Bit Rate Type -- CBR
Bit Rate -- 6144
Frame Interval -- 40
