I am trying to setup the poe switch for a NV4116E-HS. There is a menu item under the network setting for switch asking for the ip address, subnet mask and default gateway. My gateway for the router is at 192.168.1.1. And the router assigns ips beginning at 192.168.1.100. When I give the switch an unused ip address of say 192.168.1.150, I get an error message "switch and the device shall not in the same network segment"
The user guide has no instructions on how to setup the switch. Could someone help me?
setup of poe switch in nvr NV4116E-HS
Re: setup of poe switch in nvr NV4116E-HS
Suggestion:
Leave the Switch tab at it's default settings, and then follow all the setup steps in the NVR Quick Start Guide.
