no reset
lagrabow
no reset
Post by lagrabow »
I am having trouble with one of my IP3M-943 cameras.
I had it connected wirelessly and it kept losing connection [even though it is only 20 feet from router], so I ran a [new] cat cable and hooked it up.
It is also hardwired electrically by a proper voltage adapter that has been checked and is working properly.
The problem is that I tried to hard reset it to get it setup after I wired it and it won't reset.
It goes through the reset stages of the lights flashing and finally seeing the red and green solid, but it does not stay there [red & green solid], it always stays there for a minute or so and then flashes red and then solid red. I have tried a few times but it is always the same.
It does not show up on the config tool and only showed the 1st time on the nvr but I could not change anything.
What could be the problem?
Is there anyother way to reset the camera?
IP cams - Amcrest 943W [2- wired, 2- wireless], Dahua [1 wired]
NVR - NV4108 with 1TB HDD
