Limit storage time on microSD cards
jnw
Post by jnw »
Is there a way to limit the time snapshots/clips are saved on the microSD card? I didn't see any an option but I'm hoping I just missed something. I'd like to limit available saved content to only the past 24 hours, since I'm only using this camera for face detection. I've noticed with some of the API calls I use to pull clips on face detection, sometimes it returns old clips that aren't relevant even though I provided a completely different timestamp. Since the error appears to be on Amcrest's end, the only workaround to prevent this that I can think of is to artificially limit how long data is stored on the SD card.
Is this possible? Even scheduling data purges, if not setting a time limit for how long saved clips last?
