I have a recently purchased Amcrest HS4116E-HS NVR.
I tried to connect a Logitech wireless keyboard and mouse.
Both the mouse and keyboard operate from a single USB receiver.
The mouse function works fine with the NVR but the keyboard does not work at all.
When I test the keyboard and mouse on a computer both work fine so I know these Logitech accessories are working properly.
Does anyone know if the HS4416E-HS compatible with a an external keyboard?
If not wireless compatible will it work with a wired USB keyboard or is it just not compatible with any external keyboard.
Thanks in advance for any info you can offer.
Ed
Keyboard connection to Amcrest NVR
Re: Keyboard connection to Amcrest NVR
I’ve got the same problem/question. You actually don’t need it very often after the initial setup is complete but I feel very strongly that a keyboard should be supported.
