Thanks for the response. Sorry, that I didn't clarify. I did redo all my settings and set up motion events to record in the Event>Video Detection and have it enabled.geronimo wrote: ↑Tue Sep 24, 2019 6:40 amIf you reset to factory defaults, you'll need to set up again what you want to record.japhule wrote: ↑Tue Sep 24, 2019 1:28 am I updated to the new firmware and reset to default settings. For some reason my camera is now recording and saving all footage, and not the triggered motion events. Any idea why this is happening? I'm not seeing any setting that is causing the constant recordings. When I view the motion detect settings, I'm not seeing anything that is triggering an event. All recordings captured saved to my FTP. For each hour, i'm seeing 7-8 videos that are 8 minutes each.
For motion events to record, you need to go to "Event", "Video Detection" and check the box for "Enable". Then, you will get motion events recording again.
If you don't want to record 24/7, then you need to go to "Storage", "Schedule" and create a different schedule for constant recording, the default is 24/7.
You can also set the package size at whatever you want, I think the default is 8 minutes. Go to "Storage", "Record Control" and enter the "Pack Duration" to however many minutes you want from 1-120.
Remember, after making any of these changes to "Save" the changes before exiting.
Under Storage>Schedule, there are 3 options 1) General 2) Motion 3) Alarm. My default settings have recordings set for "Motion" and "Alarm" with nothing for "General". The only lines showing in the Schedule are the yellow (Motion) and red (Alarm) with nothing green (General). I'm assuming "General" is the constant recording option but please correct me if this is not correct.
All of these are saved but I still get constant recordings.
I'll also add that for some reason, all of my recordings older than 1 day are also being deleted from the FTP. This is similar behavior to the older firmware that had this issue (I'm positive that I'm on the new firmware, V2.420.AC00.18.R, Build Date: 2019-08-03). I do not have the setting to delete old files under System>AutoMaintain enabled so it is odd that this is happening.
