INDOOR / OUTDOOR SETUP
DYNO
Post by DYNO »
I would like some recommendations on the following:
1. One and maybe two camera sewtup that will monitor a small driveway and front entrance with high quality picture (20 x 40 size of driveway)
2. able to withstand temperatures that in the winter dip below 30 degrees Celsius
3. have the ability to see at night
4. POE type cameras and plan to use powerline adapters as power / ethernet setup
5. two way audio is great however is not required
6. the ability to view the video on apple and android devices and a windows PC - will use Blue Iris
7. prefer bullet type versus dome only because I can hide the bullet type cameras easier
8. want to have one maybe two cctv for the house
9. For the outside cctv would like the ability to get a better lens - maybe 6mm or better
10. I am a bit techy so I would like some honest feedback on setting these cams up as to how easy they are
Anything else that I should consider please let me know. I live in Canada and I have looked at Amcrest and here are the models I have looked at and would welcome feedback of any sort:
Amcrest UltraHD 2K (3MP/2304TVL) WiFi Video Monitoring Security IP Camera with Pan/Tilt, Dual Band 5gh/2.4ghz, Two-Way Audio, 3-Megapixel (2304x1296) @ 20FPS, Wide 90° Viewing Angle and Night Vision IP3M-941B (Black) IP3M-941B
Amcrest ProHD Outdoor 4MP POE Security Bullet Camera - IP67 Weatherproof, 4MP (2688 TVL), IP4M-1025E (Black) IP4M-1025EB
Amcrest UltraHD Shield 2K Dual-Band WiFi Video Security IP Camera w/ Two-Way Audio, MicroSD Recording, Super Wide 140° Viewing Angle, Full HD 3MP(2304×1296) @ 30FPS and Night Vision IP3M-HX2 (Black) IP3M-HX2B
thank-you for everyone's help
