How to access cameras when using NVR
Spud980
Post by Spud980 »
I have random problems with cameras 'failing to connect' when I view on the app. When I check the NVR, I have a message that, that port is already in use, would you like to add this camera to that port. Its totally random and happens with all the cameras.
I wanted to access the setting to each camera and check, also change their passwords. How do I do that when I'm using the NVR through P2P? I tried using the computer app but it wont let me pass A browser extension that needs to be installed.
idea's? I called and got bad/rushed customer service. I just wanted to see if all my network setting were correct. I have the NVR connected (Ethernet) to a Verizon extender in my den which is hardwired to the Verizon fios router in my living room.
