HDCVI 720P 8CH - Requested Fixes and Enhancements
heycraig
Post by heycraig »
Amcrest,
Please consider addressing the following fixes and enhancements in an upcoming firmware update...
Fixes:
-Fix snapshot mode from switching back to "Timing" when set to "Trigger" (seems to be an issue in both web and logged in locally to DVR).
-In the Web interface, under Event for "Detect" options, make the "Record Channel", "Tour" and "Snapshot" selections by channel follow the channel number selected in the drop down above. Currently It stays at channel 1 no matter what channel you are working on.
-In the web interface, the "Alarm" screen does not display anything even when options are selected on the left under "Alarm Type" and "Operation".
Enhancements:
-Allow user to disable email alerts for "Motion Detect" and "Motion Detect Clear" when email snapshot attachment is enabled.
-Add the "Sync" playback option to the web and PC versions of the interface, like is available when logged in locally to the DVR.
-Allow for more complex passwords.
Thank you.
linflas
Re: HDCVI 720P 8CH - Requested Fixes and Enhancements
Post by linflas »
All great ideas!
+1 here for these fixes/quality of life improvements
Amcrest 1080P HDCVI 8CH 4TB DVR Security Camera System w/ 8 x 2.1MP Bullet Cameras
That is the system I own
Raheel
Post by Raheel »
Hi there heycraig,
Thanks so much for your feedback! I will definitely add this to our consolidated list and work with our R&D department to try and fix some of these issues. Please feel free to add to this thread with any additional issues or concerns you have with the product.
Juli
Post by Juli »
Hello!
I need to know whether the camera Amcrest ProHD 720P 8CH Video Security System - Eight 1.0-Megapixel (1280TVL) Outdoor IP67 Bullet & Dome Cameras, 2TB HDD, Night Vision, Remote Smartphone Access, Black Mid (AMDV7208M-4B4D-B) supports the protocol ONVIF or RIC?
Waiting for an answer. Thank you!
Juli
Post by Juli »
Juli wrote:Hello!
I need to know whether the camera Amcrest ProHD 720P 8CH Video Security System - Eight 1.0-Megapixel (1280TVL) Outdoor IP67 Bullet & Dome Cameras, 2TB HDD, Night Vision, Remote Smartphone Access, Black Mid (AMDV7208M-4B4D-B) supports the protocol ONVIF or RTSP?
heycraig
Post by heycraig »
Well my DVR gave up the ghost after just over 2 years of use. Never was truly satisfied with this DVR. Paid $120 for a Dahua HDCVI HCVR, and put the old hard drive in it. The Amcrest units are all based on Dahua engineering anyway, so decided to go to the source. The Dahua unit seems to be more feature-packed for about the same price. ONVIF, Face Detection, IVS are all included on this unit that cost me as much as a same-model replacement unit of my old Amcrest HDCVI DVR.
