@chileheadcraig...
I managed to sort the continuous recording issue out and I hope this helps you, too.
My
Event >> Video Detection >> Anti-Dither setting was on 1. I changed this to 10 and now the system continues to record, if motion continues in the frame.
The Help page for the Anti-Dither parameter states:
System only memorizes one event during the anti-dither period. The value ranges from 0s to 100s.
If I understand this rather vague documentation correctly, the 'event' means the triggered recording event and the value of 10 would mean to check every 10 seconds for another event. If there
is another event, then reset the
Event >> Video Detection >> Record Delay timer. My Record Delay is set to 60 seconds.
The Help page for the Record Delay parameter states:
System can delay the record for specified time after alarm ended. The value ranges from 10s to 300s.
Again, if I understand the vague documentation, this simply means how long to continue the recording after the last detected alarm (triggered event). Not, how long to delay before recording begins, as could be misinterpreted.
So, with Anti-Dither on 10 and Record Delay on 60, my camera will record for 1 minute when a motion event is detected. It will keep checking every 10 seconds for another motion event and continue to record if it is already doing so. When there is no more motion, my camera will just record for 1 more minute after the last motion event was detected.
Why my original Anti-Dither setting of 1 did not work I have no idea. It should have checked for motion every second. Maybe the fact I use a NAS to record has something to do with it and a setting of 1 is too short a period for the firmware/network combination to react to? Maybe some drives which are set to spin-down (sleep) might be a problem, too, depending on how long it takes them to wake up?
Anyway, hope this helps you
@Amcrest Support...
Lack of a manufacturer's support influences whether or not people buy your products in the future. I have received 0% support on this topic and, needless to say, this will influence whether or not I purchase your products again.
