hello
I have 2 amcrest DVR
8 Channels with 8 bullet camera
all together 16 cameras
I would like to know if is possible to connect the dvr between them as long as they are not at the same place but use the same network
Amcrest HD 720P 8CH Video Security System - Eight 1280TVL 1.0-Megapixel Weatherproof IP66 Bullet Cameras, 65ft IR LED Night Vision, 2TB HDD, HD Over Analog/BNC, Smartphone View (Black)
Connect 2 DVR
Re: Connect 2 DVR
Hello mano775,
I dont think they can be connected together. What you can do instead as long as they are on the same network is to be able to view them all from a PC using the web interface. If you use the Amcrest surveillance pro software, you can then add two DVRS to the software and watch all cams from the same software.
Re: Connect 2 DVR
Hello!
I need to know whether the camera Amcrest ProHD 720P 8CH Video Security System - Eight 1.0-Megapixel (1280TVL) Outdoor IP67 Bullet & Dome Cameras, 2TB HDD, Night Vision, Remote Smartphone Access, Black Mid (AMDV7208M-4B4D-B) supports the protocol ONVIF or RIC?
Waiting for an answer. Thank you!
Re: Connect 2 DVR
Hello Juli,
AMDV7208M-4B4D-B doesn't supports ONVIF or RIC. You can only add specific Amcrest cameras to DVR system.
