ASH43-W ... default password not working
kfh227
Post by kfh227 »
I currently have the camera hard wired to the network. My laptop is hard wired. My phone is connected to network via wi-fi.
I verified the IP address in both my router's web page and the Amcrest IP Config application (Windows)
I have done a hard reset on the camera (hold button 20 seconds till turns red ... then eventually green again)
I've disabled my VPN software (only on laptop)
I can not connect to the camera using the default password of admin/admin. Also, admin/888888 doesn't work (I read that this will allow admin access possibly). I've tried this on my phone, with Amcrest Surveilence Pro and the Amcrest IP Conig tool.
I also assumed the camera has a web portal and trying to connect to the IP on port 37777 in Chrome does nothing.
I am at a total loss.
EDIT: Just found a tidbit. Hold the reset button till camera blinks orange .... so it goes from green to red to blinking orange?
kfh227
Re: ASH43-W ... default password not working
Post by kfh227 »
I followed these directions:
https://support.amcrest.com/hc/en-us/ar ... set-ASH43-
I never saw blinking green no matter how long I held the reset button down.
I tried releasing while orange was blinking. While orange turned solid. And held it till orange solid (after blinking ended) turned red.
kfh227
Post by kfh227 »
SOLVED!
OK, the factory reset I did worked. I waited for the light to change from blinking orange to solid orange and let go of reset.
Then this:
https://amcrest.com/forum/viewtopic.php ... h43#p37822
So you have to use the app on your phone!
Select wi-fi setup because wired seems to not work for some reason.
And when you get to wifi setup select a 2.4 GHz channel!
There, 3 hours later and it's done! LOL Now to get it working on my Synology NAS.
