I have two ASH-22 WiFi cameras. I used Amcrest Smart Home App to setup them both up and all is working great. I also have other wired cameras and I use 'gDMSS Plus' to view them. I would like to merge my Amcrest ASH22-W cameras to gDMSS Plus mobile app. However to correctly add these Amcrest cameras I need to modify the default port setting, which is 37777, to something different so that I can configure my router for port forwarding on each camera. I have successfully configured one of the ASH-22 using the default port but to add another I need a discrete port number.
Does anyone know the steps to change the ports on ASH-22 WiFi cameras?
