Adding dome cameras to Amcrest Qcam System?
I don't seem to be able to find any dome cameras listed on Amcrest direct site or Amazon, are there any other compatible dome IP based cameras that work with the system?
Re: Adding dome cameras to Amcrest Qcam System?
Short answer, no.
I bought the QCAM system recently, and before buying it, I asked tech support if it would work. Idiots over there said yes, so I got the Amcrest ProHD Outdoor 3 Megapixel POE dome camera also. Well, of course when everything arrived, it would not pull up on the NVR system at all. I contacted tech support again, and they said no, they don't work. Basically it has to do with the difference between NVR and DVR systems, and the QCAM brand. The only things that work for QCAM are the QCAM cameras, which are only the bullet style.
