ProHD Wi-Fi PTZ IR Outdoor Speed Dome
Chris
Postby Chris » Sat Dec 29, 2018 11:07 pm
Hi all,
I have 2 of the ProHD Wi-Fi PTZ IR Outdoor Speed Dome cameras that are mounted way up on the house and got the Google Wifi mesh package. I also have 4 Amcrest pan and tilt cameras in the house. My problem is the 4 cameras in the house were easy to setup on the new Google wifi but the speed dome cameras I can’t get to that easy to reset them so they can connect to the new WiFi.
Is there any way I can edit/change the WiFi settings from my tablet or smartphone.
Thanks for any help.
cjredmo_v2
Re: ProHD Wi-Fi PTZ IR Outdoor Speed Dome
Postby cjredmo_v2 » Mon Jan 07, 2019 9:50 am
Since you a new router with new settings you might have to remove the old instance of the camera and set it up again following these steps:
https://support.amcrest.com/hc/en-us/ar ... tion-Setup
Return to “General Discussion”
Who is online
Users browsing this forum: No registered users and 1 guest
