IP3M-943 mount is terrible
kenkadish
Postby kenkadish » Thu Nov 30, 2017 4:05 pm
Brand new IP3M-943 user, and while the camera is fine, the design of the mounting system is a disaster. Hard to believe that it could have been designed to provide only 90 degrees of movement, and only in one direction. No ability to move in more than one direction e.g. point the camera straight with the slot facing right, and you have to realign the mount in order to tilt the camera left, up, or down. Should be on a swivel ball like a ram mount. Imagine mounting this outside on a corner of a garage...it can be oriented to tilt down, but not right or left. Mount it so it can be moved down, and there is no ability to move it left or right. Looking for a mounting plate with a swivel, but am not having any luck.
deadeye916
Re: IP3M-943 mount is terrible
Postby deadeye916 » Sun Dec 03, 2017 10:49 pm
I agree 100%. Poor design by Amcrest on this mount.
Eagle85
Postby Eagle85 » Tue Dec 05, 2017 11:04 am
I recently installed an IP3M-943 and also had to battle with that very poorly designed mount in order to properly orient the camera.
nukezero
Postby nukezero » Wed Dec 06, 2017 3:23 pm
You guys got it wrong, like I did. You need to loosen the screw at the stem... that silver screw allows you to rotate the entire base. I didn't know about this until I watched a video on youtube a year later! LOL. I always thought that you had to pick the orientation first before you drill onto the wall, but that is not the case. You can pick any orientation to mount on the wall, then loosen the philips screw to rotate as you please.
I own eight IP3M-943s, four IP4M-1025E, one IP4M-1026E, and two IP2M-841. I know what I'm talkin' about. The 1026 bullet has one of the best mounts with 3-axis of rotation (3 adustment screws).
evillord
Postby evillord » Sat Dec 09, 2017 1:39 pm
Nuzezero,
Thank you for the tip, I bought 6 of thse cameras and installed 2 so far with the same frustration as those above.. i do really like the cameras so far!
seraniz
Postby seraniz » Sat Feb 16, 2019 1:10 pm
kenkadish wrote:Brand new IP3M-943 user, and while the camera is fine, the design of the mounting system is a disaster. Hard to believe that it could have been designed to provide only 90 degrees of movement, and only in one direction. No ability to move in more than one direction e.g. point the camera straight with the slot facing right, and you have to realign the mount in order to tilt the camera left, up, or down. Should be on a swivel ball like a ram mount. Imagine mounting this outside on a corner of a garage...it can be oriented to tilt down, but not right or left. Mount it so it can be moved down, and there is no ability to move it left or right. Looking for a mounting plate with a swivel, but am not having any luck.
Traveling Guy
Postby Traveling Guy » Mon Feb 18, 2019 2:11 pm
While you can rotate the camera by loosening the screw, there is another problem. if you want to install it at 90º to the wall there is clearance for the antenna in only one direction. Standing in front of the camera, if you turn the mount to the 3 o'clock position the antenna is in the way, so the swivel cannot be turned a full 90º, maybe 80º tops. I had to mount mine upside down as it you turn it to the left the camera and the mounting flange will be parallel.
Am I missing something here????
Return to “General Security Chat”
Who is online
Users browsing this forum: No registered users and 0 guests
